PFS translate file disappears from directory
CamilaGasque
Version de PhotoFiltre : pfs 10.8.0
Système d'exploitation : Windows 8
Processeur : intel celeron
Mémoire RAM : 2
Message par CamilaGasque »
I have PhotoFiltre Studio v 10.8.0 and I installed it on my mom's pc (windows 8 ). She wanted me to translate to Brazillian portuguese and I tried to do this replacing the StudioEN.plg file for the StudioBR.plg. I did this succesfully, but when I open the program the file disappears from the directory and the language is changed to french. Do anyone here knows how to fix this? Thanks in advance!
Re: PFS translate file disappears from directory
the file is removed ?
not possible...are you sure ?
CamilaGasque
Mémoire RAM : 2
Yes, sure! I tried to place the file on the directory several times, but this keep happening.
It is not photofiltre, no code for this, don't understand :cry:
Try to download the last version 10.9.2 :
http://www.photofiltre-studio.com/download-en.htm
