File selection window size
trogladyte
Message par trogladyte »
Is there a way to increase this microscopic window size so I can see more than 3 or 4 files at a time? It's not even draggable - this has annoyed me for years and I finally got sick of it today.
Thanks.
Re: File selection window size
what window ?
trogladyte
Sorry - too vague in my question. Image attached - I am referring to the file open window.Image
what is your windows version ?
with Vista+ you can use the new windows file dialog box (can be resizded)
trogladyte
Sorry (again) - Win 7 and there's absolutely no way that Open Dialog window is resizeable.
All my open dialog box can be resizeable with windows 7
Perhaps you disabled Advanced display ?
With PFSX and PF7, you can use default windows 7 dialog box :
Menu Tool > Preferences > Windows 7 & Vista > uncheck XP dialog box
trogladyte
Ahhhh - therein lies my problem. Somehow I was still using v9 even though I have a PFSX license! DOH! Thanks.
