All fonts in Photofiltre 10.7.1 are not working
karlik1982
Version de PhotoFiltre : 10.7.1
Message par karlik1982 »
I was working in Photofiltre and after I did some pictures I needed insert text into it but all fonts stopped working.
It doesn't matter what font I use, the text is all the time same...just 1 basic font...
I have no idea how to make them work. They always worked great. In windows, all fonts are working.
Thanks
Re: All fonts in Photofiltre 10.7.1 are not working
Perhaps just restart PC...Did you tried fonts with WordPad ?
karlik1982
Yes, i tried them in WordPad and they are working.
Even in Photofiltre when I use FontShow plugin it will show them.
When I type text (in ctrl+T) I can see that font in text input but when I click on OK it will insert that text in basic font.
I used different fonts but it's always same.
never see this bug, try to download the last PFS X version 10.9.2
