Can't open files
hilaholland
Système d'exploitation : windows 8.1
Can't open files
Message par hilaholland »
I have a new computer with windows 8.1 and I can't open any file on photofilter. I can use the files on any other program but not on photofilter. I need some help.
Re: Can't open files
what is your file format ?
hilaholland
Any file I make JPG PNG I can't save or open on photofilter.
can you post an image here to test
hilaholland
I don't know how to add image here. but it happens with any image I try.
In you screenshot I see that the folder used to store image are not compatible with photofiltre because you use special char.
Move your images in a folder callled 'C:\MyImage' for example to test
