Channel "purple" to "magenta"
scootergrisen
Message par scootergrisen »
When you adjust an image you can select color channels.
But one of them is called "purple", but i think it should be called "magenta".
Code : Tout sélectionner
TrMnuClPurple = 'Purple';
TrMnuClPurple = 'Magenta';
And change TrMnuClPurple to TrMnuClMagenta to.
Re: Channel "purple" to "magenta"
i can not change the menu name because in this case i must change all translation language an my source code :cry:
scootergrisen
You can do it :clap:
