Use as wallpaper menu
scootergrisen
Message par scootergrisen »
In the menu for using the image as wallpaper you have three options but between number 2 and 3 there is a separator.
Why ?
Re: Use as wallpaper menu
just to separate :wink:
scootergrisen
Yeah but why ?
There are three different options for setting the wallpaper.
Why not just show the three options without seperation ?
If you seperate the last item it seems like there should be something speciel about it. But theres not, its just a option like the other two.
no, the image is resized to fit the screen
scootergrisen
So why not remove the seperator ?
because i don't want :wink:
