When changing image size or canvas size there is missing a space:
...memory(Background)
...memory (Background)
When using Edit > Paste special > Assemble... the choices for right, left, etc. are not so good.
Right is on the left and left is on the right.
It would be better to have choices like when changing image where you can select a little square.
When using Selection > Load shape... is says with big S:
PhotoFiltre Selection
PhotoFiltre selection
View > Layer thumbnail could have these changes:
Normal size > Normal
Small size > Small
Text > Text only
In ? menu it says "Information".
Better to write what kind of information. Like "Manual" or "Help" or what ever. F1 is normally the shoutcut for Help.
Suggestions for string changes
scootergrisen
- Habitué(e)|Habitué|Habituée
Dernière modification par scootergrisen le 11 avr. 2015 19:18, modifié 1 fois.
Re: Suggestions for string changes
i will check this
scootergrisen
In animated GIF dialog it says "All Images". Where i would like "I" to be small in my translation.
There are multiple places in the program that a string starting with big letter is taken and used after another string.
"Shadows / Highlights".
I dont think 'Maximize window when opening' gives the expected result.
When opening... sounds like it will only happen when i open new windows.
But its seems to only happen on the current window.
i don't speak english very well. Some times somebody help me and sometimes i use translator, of course it is not the best english translation
==> no, it is for every new image too
scootergrisen
If it open a image it always opens maximized.
So it does not matter if the setting is on or off.
