Hi everybody.
When I send my images to print, I always get blank pages. I appreciate any help on this.
Thank you very much in advance.
Blank prints
Re: Blank prints
check your printer setting : change mode to bitmap, not vectorial for example, and drawing not text
boosterpl
- Système d'exploitation : win7 x64
- Mémoire RAM : 4
Re: Blank prints
I just buy a full version and have the same problem most times it prints blank page!!! please help. i try to change all printer settings, and reinstall drivers, i try all options and most times it prints blank pages, does not matter did i write new text or import jpg file. Please help!!!
Re: Blank prints
what is image size ? perhaps the image is too big ?
boosterpl
- Mémoire RAM : 4
Re: Blank prints
is 32kb png file! o als o print text from text box and still is BLAK page, But when i print to pdf creator than is okay. Any settings in printer including reinstall new drivers wont help!!! I cant print from program directly to printer!
Re: Blank prints
Try to force image to RGB 24 bit before printing using the menu Image > Mode > RGB
