Danish (da) translation
scootergrisen
Message par scootergrisen »
I would like to work on the danish (da) translation of PhotoFiltre but its not clean how to do it.
On http://www.photofiltre-studio.com/download-en.htm is says "Needs update but works with the last version !", but it does not say how to make changes.
Also there is only link to a PLG file which seems to be a RAR file with compiled file.
I dont see any link to the source files.
Re: Danish (da) translation
Contact me by e-mail and I will send you the text file to updtae. After I make the new PLG
scootergrisen
Would it not be better to make the text files available online so more people can look at them and help make it better ?
On http://www.photofiltre-studio.com/download-en.htm it says "Translated by www.digitalmagasinet.dk..." but this website don't not seem to be in use anymore, it seems to be overtaken by some crap website.
scootergrisen
How do i make StudioDA.pas file into StudioDA.plg so i can test my translations in the program.
I think there should be a page on how to translate/test/update/improve PhotoFiltre so it can be easier.
you can not, send me the .pas file, i create the plg
