fade button
Jim Clatfelter
fade button
Message par Jim Clatfelter »
I woulld like to see a Fade Button. I use fade on almost every photo I edit. It could be near the Undo button. I never use reinforce and seldom need sepia, old photography, or relief. FADE would be 100 times more useful .
Fade is such a powerful feature. It should be very accessible, imo.
Jim
Jim Clatfelter
faDE
FADE is really a partial UNDO command (Shift-Ctrl-Z) isn't it? Other programs don't have this versatile and powerful feature. I think PhotoFiltre should be proud of it. It should have a button just like Undo and Redo. Photoshop Elements doesn't have this way of fading.
FADE UNDO REDO
This trio belongs together, easily accessible on a button. This is almost unique to PF. It makes precise editing so easy. Why not advertise it?
Jim
Is what you're saying not the Edit/Fade function ? :)
Jim Clatfelter
Edit / Fade
Yes!
I use that one on every photo I edit. It's such a powerful function. I'd love to see it on a button -- right next to the UNDO and REDO buttons. FADE is a partial UNDO. Who else besides Photoshop has it? I think a FADE button would make editing with PF so much easier and faster.
Thanks for considering it,
Jim
why not in the future version :wink:
Jim Clatfelter
fade button
Thank you Antonio.
That will be wonderful!
Jim
Jim Clatfelter
fade key
I've remapped my keyboard to work with PhotoFiltre Studio. The minus (-) key on the numeric keypad is now the fade opacity key. The plus (+) key is for a duplicate image. The divide (/) key is for stroke and fill. The multiply (*) is to merge all layers.
Incidentally, the copy and paste buttons work great for making duplicate layers fast. Paste as many duplicate layers as you want.
More than one way to skin a cat!
Jim
echo0001
Version de PhotoFiltre : 6.1
Système d'exploitation : Windows 98
Mémoire RAM : 64mb
Message par echo0001 »
Yes! It would be really good to have a Fade button. This is definitely one of the best features of PF (any version), and it would be so handy to have it on a button.
I hope it is added to future versions of Studio.
Jim Clatfelter
fade button
I'm glad to have an echo and an ally on this.
Thanks for speaking up.
Jim
Don't forget the hotkey Ctrl+T :wink:
Jim Clatfelter
hot key for fade
The hot key for FADE has been changed to Shift-Ctrl-Z.
Somebody realized that this key is closely related to UNDO (Ctrl-Z).
Shift-Ctrl-Z. is a little bit awkward to use, for me at least. A button would be much easier. And it would call attention to the ability of PhotoFiltre to execute a PARTIAL UNDO.
Jim
