Photofiltre automation
soapbox
Version de PhotoFiltre : 6.5.3
Système d'exploitation : Win 8.1
Processeur : Intel 5960X 8-core (16-threads)
Mémoire RAM : 64GB DDR4
Message par soapbox »
Is there any way to automate/batch process things like "automatic crop" or "Dust reduction - high"?
I don't see these filters available in automation settings. Can they be added as command line?
Re: Photofiltre automation
only filters available in the automate are enabled, not other...
soapbox
Any chance you could add "automatic crop" and "dust reduction - high" to batch options/filters?
Or is there any other way to automate these? Command line maybe?
This would save me months of work...
automatic crop works only for some image with background and dust reduction need setting for each image for a correct result. Then for the moment not possible
soapbox
I have 10,000+ black and white comic book drawings that I would like to run through "Dust Reduction - High (default threshold: 0)". How can I do that using batch processing? Doing it manually for each individual drawing will take forever...
of course for this it is better another software like XnView :oops:
soapbox
Thank you for suggestion.
Which NConvert filter would be most similar to your Dust Reduction - High filter? It is fantastic for clearing up the line-art drawings.
don't know but i think we use classic methode :wink:
soapbox
Looks like XnConvert>Action>Filter>Median Box 7x7 produces exactly the same result as your Dust Reduction - High filter. :-)
So thank you again for suggesting Xn Software. Of course, I am still using PF for many other things that cannot be automated.
