Fast correction
Mészáros Tamás
- Version de PhotoFiltre : PhotoFiltre Studio 10.13.1
- Système d'exploitation : Win 7 Home Premium SP1
- Processeur : AMD II X2 Athlon 265 3.3 GHz
- Mémoire RAM : 8 Gbyte DDR3 2133 MHz Predator Kingston RAM
Fast correction
In RAW format possible the quick correction under PFS 10.9?
Re: Fast correction
What exactelly ? For raw format it is better to use the camera software because more options to convert raw to jpeg
Mészáros Tamás
Re: Fast correction
RAW editing. IPS monitors have much better color quality in RAW format. Professional photographers to edit RAW format.Antonio a écrit :What exactelly ? For raw format it is better to use the camera software because more options to convert raw to jpeg
PhotoFiltre Studio is open, but it does not save the RAW file format.
