How to set default saving to 1200, 600 or 300 dpi?
miamiflower
Version de PhotoFiltre : v. 6
Système d'exploitation : win7
Message par miamiflower »
I have my camera settings to 12MB photo, but when I view it in PF for the first time, an then go to close it, it wants to default to 180dpi, or worse, 72dpi. I can't find how to set the default to 600 or higher.
Re: How to set default saving to 1200, 600 or 300 dpi?
There are not defaut dpi, photofiltre use the image dpi when saving.
To change it go to the menu Image > Image Size, change unit to cm/inch and set the wanted dpi
miamiflower
That is what I have been doing. It is problematic, however, and I have saved many photos at too low a dpi because I forgot to change it, and it did default to 72dpi when I closed and saved the image. It would be great if the designer of PF added this default feature. Other programs have it.
