Unable to locate tools
pfaoro
Message par pfaoro »
I'm new to PhotoFiltre and having difficulty keeping track of where certain tools are located. At various times I have found, and used, all of them but can't recall where I found them the next time I need them.
Will some kind soul please tell me what these tools are called, and where I can find them:
  • [A] Rotating a selection I've pasted into a different image,
    Resizing a selection, and
    [C] Moving a selection I've pasted into an image to where I want it.
Thank you VERY much!
Re: Unable to locate tools
Hi pfaoro,
you can find a translation tool of the documentation for PhotoFiltre Studio and 7 at this adress :
viewtopic.php?f=21&t=14191
After the paste, the selection is a layer become.
So the relative tools are in the Layer menu and in the richt clic of the layer thumbnail.
Right clic in the selection or Selection menu
Attention : you could confuse "selection" form with the contents of the selection. Each object has its specific tools.
You can for example paste a selection form from one image to another : menu Selection / Copy shape and Paste shape.
A selection can be displaced with the arrows (+ Shift key = step by 8 pixels) or with the mouse.
When you have copied a selection contents, you can also paste it in a pasted shape for special use.
