Resize text area without resizing text
digiscrap
Version de PhotoFiltre : PSX 10.8.1
Système d'exploitation : Win7
Processeur : i7 / Duo
Mémoire RAM : 6GB / 2GB
Message par digiscrap »
Hello,
Is it possible to add text in a 'block' and resize this 'block with text' to fit on a layout. The text should not resize, only filling out the area. In PFX I can resize a block with text but the text is also changing or resized than...
Or, is there an other way to do this? Like drawing a block and fill it with text. The text must be placed inside this block.
I hope you understand what I mean :oops:
Thanks,
Vincent
Re: Resize text area without resizing text
not possible in auto but you can change text spacing nto ntry to fit manually
digiscrap
Thanks for your answer! I'm going to try this in Inkscape and paste the text block as an image into Photofiltre.....
I really hope this will be implemented in a feature version ;)
Vincent
