Cannot open files from mapped network drives
Matej
Version de PhotoFiltre : 10.1.0
Processeur : Intel Dual Core 2,66
Mémoire RAM : 2GB 800 MHz
Message par Matej »
Latest PF version on Windows 8 is not able to open *.pfi file from mapped network drive. Application crash. Please fix it. I must copy each file from network drive into local drive and then edit and copy it back.
Re: Cannot open files from mapped network drives
:( Sorry for you, but under W 8.1, even if the target is not visible in the Windows Explorer,
i can load a 88 Mo pfi file from an other network DD, by given the file path in the Open windows of PhotoFiltre Studio.
We will see that Antonio wish to say for this point, but it seems the problem is elsewhere.
