I have tried to install either one of the 2 red eye removal plugins with no luck for 6 months. I use to have photofiltre 2 years ago and lost it when I had to get a new computer I downloaded 7 and now when I download the plugin and move it photofiltre pugin folder it says cant open file, also my computer says it doesnt recognize the type of file either. I really need some help to get this installed as I take photos of our rescue dogs to put on the internet for adoption. Any guidance I would be so greatful
Thanks
Keath
red eye plugins
keathr
- Version de PhotoFiltre : 7
- Processeur : amd dual core
- Mémoire RAM : 8
Re: red eye plugins
what is the exact error message ? you unziped the content of plugin ? don't put directelly the .zip in the plugin folder
Re: red eye plugins
Hi keathr,
The process to install a plugin is discribed down this page : http://www.photofiltre-studio.com/plugi ... ins-en.htm
- The downloaded file has to be unzipped, before to be displaced in the Plugins folder, and PhotoFiltre has to be re-openned
- The plugin file does not be openned like an executive Windows file.
- The red eyes plugin has to be openned by PhotoFiltre in the menu Filter / Plug-in
Ha ha !!! Antonio is faster
keathr
- Mémoire RAM : 8
Re: red eye plugins
the compute says it does not recognize the file type and it goes to microsoft to find what is needed and it cant find what I need either
