Having trouble using Masks
xialle
Version de PhotoFiltre : 10.7.3
Processeur : No idea
Mémoire RAM : No idea
Message par xialle »
Hi. When using Photofiltre and using my masks, the program usually opens the mask folder located in the computer section in the Photofiltre folder. All of a sudden, the mask button opens to my last saved folder, which is stored in a completely different section, not even in my Photofiltre folder. I've tried uninstalling and reinstalling the program. Any ideas on how to fix this? It's extremely annoying and makes everything much more difficult.
Re: Having trouble using Masks
I think it would be not very hard to fix. :)
Indeed the Mask module opens with the path of the last mask used.
Il you left click on the folder icon at the right side of the path in the Mask module,
you would see the Open window displaying the correct folder of PhotoFiltre/Masks,
chose any mask and validate the Mask module, exit PhotoFiltre without saving (if you didn't want keep the result)
At the next use of PhotoFiltre and Mask module it will open on the last mask used :
- i.e. the last used in the Masks folder of PhotoFiltre
xialle
Thank you for your response. I don't think I explained my problem very well. For example, I am working on a project. I open the mask module to apply a new mask. When I click on the folder in the module to choose a new mask, instead of getting my masks folder, I get my PROJECT'S folder.
All right, but when you use the Mask module with a mask selected in the Masks folder of PhotoFiltre and validate,
what happends the next time ? The folder icon of the Mask module opens still the project's folder ?
xialle
Yes! It opens on the mask I used previously, but if I want to use another mask, when I click to open the masks folder on the module, it takes me to the project's location.
I don't encounter this problem and can't reproduce it.
If you change the settings in Preferences / Default values, does it works as usual ? I have uncheck Automatic
xialle
Yes, I've tried changing the settings in Preferences....:( It's very strange. One day it was working fine, and then the next it wasn't. I've started putting a shortcut to my masks folder inside my project folder....that way I don't have to go through all the levels of folders to get to the masks. It's working okay, but I'd rather have it working the right way. :) If you have any other ideas, I'd love to hear them! If not, thank you SO much for your time!
The last release of PF Studio X is 10.8.1
Some evolutions were done since your 10.7.3, may be could you find some benefit ?
xialle
I hadn't thought of that, but it's a good thought. I'll give it a try and see what happens. Thanks!
