Error resizing/renaming images
Erick
Version de PhotoFiltre : 7 & 6
Message par Erick »
Hi,
I'm having some problems with Photofiltre 6 and 7. Both have the same issues during the proces of renaming and resizing images. It says that some of the pictures (all jpg) cannot be resized and appear as "empty" images that can't be opened in the folder with the images that can be resized.
Anybody that knows the cause of it?
Re: Error resizing/renaming images
perhaps memory error, image too big ? what is image size before and after resize ?
Erick
Message par Erick »
The images (25) have a size of 4512x3000 px (3.62 MB) and i wanted to resize them to a width of 900px. Earlier i tried with another set of images without problems. Those (271) had a size of 5184x3456px (7,7 MB). I resized them to a width of 120px.
I don't know if it is an memoryproblem. How can i test that?
try to reboot the pc
