Replace color using a custom palette
kilele
Message par kilele »
Hi
I'd like to use the adjust->replace color using a custom palette or rather the possibility of using the pipette tool outside the image, for example to select a color present in other images opened in the same view, a palette image, etc
Re: Replace color using a custom palette
It's not possible to use a custom palette because PhotoFiltre recalculates the palette when saving :cry:
kilele
So it may be a nice feature :)
At least to be able to pick colours from different images than the one where the user wants to use the replace tool.
not sure, who use today indexed mode :wink:
now lot of people use PNG True colors :oops:
