Hi !
I am using Photofiltre Free 7.
I want to add to my photos a border as a 35 mm film, as if they were old slides.
What tools can I use ? I need a mask of a 35 mm film ? Or a border ?
Thanks for any help,
Enrico
35 mm film border mask
chicchio
- Version de PhotoFiltre : 7.0.1
- Système d'exploitation : xp pro sp3
Re: 35 mm film border mask
You can use a mask with black colour upon a new white form of the size you need.
then you select the white area in the middle of your form, copy the image you wish to insert,
and right clic in the selection to use the "Paste in" function .
Some masks in this topic : viewtopic.php?f=7&t=10155&p=94296&hilit ... ilm#p94296
