Will this work with 64bit Win7 Pro
Indy
Message par Indy »
Right now I am using PhotofiltreStudio on an xp pc with no problem. I have a license so I can download newer version. I want to know if this will work on Win7 Pro 64bit as I am not sure I want to get a pc with Win8 yet but thinking about Win7 Premium and Win7 Pro 64bit. Want to consider Win7 Pro 64bit for Xp virtual mode for Jasc PSP9
Thanks for any help.
Indy
Re: Will this work with 64bit Win7 Pro
lot of users in this forum works with win7/64 bits :wink:
Mészáros Tamás
Version de PhotoFiltre : PhotoFiltre Studio 10.13.1
Système d'exploitation : Win 7 Home Premium SP1
Processeur : AMD II X2 Athlon 265 3.3 GHz
Mémoire RAM : 8 Gbyte DDR3 2133 MHz Predator Kingston RAM
Message par Mészáros Tamás »
Indy a écrit :Right now I am using PhotofiltreStudio on an xp pc with no problem. I have a license so I can download newer version. I want to know if this will work on Win7 Pro 64bit as I am not sure I want to get a pc with Win8 yet but thinking about Win7 Premium and Win7 Pro 64bit. Want to consider Win7 Pro 64bit for Xp virtual mode for Jasc PSP9
Indy
I'm use Win 7 Home Premium SP1 64bit. Very good.
