About Jpeg compression used by library you are using in Photofiltre now
It uses by default YUV 122 component sampling, It's fast, the result jpeg file will be smaller, BUT IT'S too lossy for colors (especially red ones), as result - the image will be much blurry and lost many details. So even 100% quality in this mode - great loss of true colors. I myself use only AcdSee v3.0 for Jpeg compression, There I can chose the YUV better compressions method - YUV111. So If I chose 100% quality - The result photo should have NO changes at all.
Antonio, I recommend you to replace the Jpeg library you are using (OR if there are YUV 111 sampling option - to add it as option when compression percents asked)... If there are no such funtion - it's better to find another Jpeg compressor library.
Here you can look for example of compression quality loss:
http://coraksoft1.narod.ru/temp/YUV111/15okubok.png
(Original lossless Image in PNG)
http://coraksoft1.narod.ru/temp/YUV111/ ... yuv122.jpg
(Compressed 90% with YUV122 sampling, great loss of colors, 30% less file size, some blurring)
http://coraksoft1.narod.ru/temp/YUV111/ ... yuv111.jpg
(Compressed 90% with YUV111 sampling, no loss of colors)
Found some thread about this:
http://www.breezesysforum.co.uk/forum/a ... t-114.html
So real deal I think is to turn off downsampling in jpeg method.
Here's also (Jpeg sub sampling / chroma sub-sampling):
http://www.cerious.com/help8sp1/jpeg_sub_sampling.html
http://users.wfu.edu/matthews/misc/jpg_ ... maSub.html
http://www.ece.ucdavis.edu/cerl/Reliabl ... /jpeg.html
