What is Twain, and how would I use it?
Shinnen
Processeur : Intel p4 2800mhz
Mémoire RAM : 1.5 gig
Message par Shinnen »
Hi,
Thanks,
....... john
Re: What is Twain, and how would I use it?
I think it is better to search in the net for twain definition, i'm not an expert :wink:
Shinnen
Hi Antonio,
I thought that since 'import twain' was in your menu, that you would know what it would be used for. But I will check the net.
Thanks,
..... john
it is to use the scanner or a camera using twain mode
Shinnen
Thanks. I was just curious.
I've seen it many times, but never really knew what it was for.
...... john
