rubber??(Gomme)
none
rubber??(Gomme)
Message par none »
Hello
sorry-i don't speak french
i downloaded the latest version of photofiltre but can't find the rubber(Gomme)
Where it has been gone?
I don't want to use another software than photofiltre but without the rubber it is useless for me
thanks for reply
:wink: rubber is present in photofiltre studio (you can download it in the forum, use "search" toll to find it.
on the free 's version (photofiltrev;6.1.1) you can use the brush: color white(or an other one) as a rubber.... :wink:
Invité
brush
Message par Invité »
when i overlay 2 pictures and use the brush to delete parts of the overlayed its only white but i need to see the 2nd picture
and photostudio is only shareware
To doing this, the software need manage layers
Invité
no dont need manage layers
as i remember in earlier versions there was the rubber included
WHY you remove it?????????????????????
it was easy to use copy an part of an picture into another and rubber till it fits
cant find an link to older versions of photofiltre
MightyKitten
Version de PhotoFiltre : 6.1.1 NL / 7.0.1 NL
Système d'exploitation : Windows XP Pro/SP2
Processeur : Pentium IV @ 2,66 Ghz
Mémoire RAM : 704 MB
Message par MightyKitten »
I understand that an eraser to transparancy can come in handy when u are creating GIF or PNG files, since they make use of transparancy. But....
Transparacny in either GIF or PNG is just a color substitute:
A specific color value will be replaced with the 'color' transparancy.
For this same reason, a pixel will be either compleetly transparent or not.
Even if you use a treshold value for transparancy all the colors in rance will first be converted to the same transparacy value.
Photofiltre Studio, However uses an alpha channel for transparancy. This is an additional byte to the color value, telling how transparent that color is. This means you can have 256 levels of transperancy.
What you could do, is picking a specific, very seperated color en use it ot erase. Pink (#FF99CC) seems to be a favorite for some reason (at least in PNG), and the convert that specific color to transparancy
An other way is to create a mask out of the foreground picture,
Edit so that everything you want from the forground picture is white and every you want from the background picture is black
Then:
Open the foreground picture,
choose menu Filter > photomasue
Set the mask to the mask you created
Set mode To Pattern
Select the backgroundpicture as pattern
This way, you also simulate (in a limited way) apha channel transparancy.
Jeroen de Bruijn
Invité
hm
doesnt work the way i like it
always looks bad- example
i put the head from an person on another body with the eraser i can make it exactly with anoter brush i got an bad looking color
i hope u understand what i mean
http://hrfakes.hr.funpic.de/ak/ak4.htm
