- mb -
Czech in PhotoFiltre Studio X
Magistr
- Version de PhotoFiltre : 10.7.1
- Système d'exploitation : Windows 8
- Processeur : Intel(R) Celeron(R) CPU B840
- Mémoire RAM : 4,00 GB
The program PhotoFiltre Studio X does not appear Czech accented correctly. The letter "Z" and "S" hook to display correctly. The letters "E", "R" and "C" hook are displayed incorrectly.I use Windows 8 when moving house, and the program was selected as compatible with Win 8, this problem persists even after the "clean boot". This applies both PFS X and earlier versions PhotoFiltre. In other programs, which are also in the English version, the Czech accented displayed correctly.
- mb -
- mb -
Re: Czech in PhotoFiltre Studio X
i think you must change windows language to other Est european or other
Magistr
Change encoding windovs language was the first thing I tried. The only result was that changed imaging Czech letters with accents on the browser page. On display errors in the Czech PhotoFiltre Studio X to have no positive effect. Coding Czech language must be set to Unicode (UTF-8) to Czech displayed properly. In other English language programs, the problem does not occur only in the program PhotoFiltre.Antonio a écrit :i think you must change windows language to other Est european or other
- mb -
Magistr
Supports program PhotoFiltre Studio X Czech language for the operating system
Windows 8? On other computers with older versions of Windows program works correctly.
- mb -
- mb -
Magistr1944
- Version de PhotoFiltre : 10.0.8
Problems with displaying Czech accented letters
The program PhotoFiltre Studio X, version 10.8.0 are not displayed correctly Czech letters with accents. Supports this program Czech language in Windows 8? On other computers with older versions of Windows in the Czech program works correctly. What can be done to remedy this defect. Transcoding language windows does not lead to a positive outcome even so-called "clean boot". Other programs in the original English version on my computer do not have these problems.
I don't use windows 8, but if it works correctelly with an old windows version, the problem is the langage code. But what exactelly ?...don't know
Magistr1944
Who should I contact to help solve the problem?Antonio a écrit :I don't use windows 8, but if it works correctelly with an old windows version, the problem is the langage code. But what exactelly ?...don't know
- mb -
Magistr1944
The problem with displaying Czech accented letters is resolved. Conclude this discussion. - mb -Magistr1944 a écrit :Who should I contact to help solve the problem?Antonio a écrit :I don't use windows 8, but if it works correctelly with an old windows version, the problem is the langage code. But what exactelly ?...don't know
- mb -
