What has happened to the 'Swap RGB Channel' option that used to reside under the Adjust tab please?
It was there when Paul B Moore published 'Experiments in Digital Infrared Photography' in 2012.
Thank you.
Swap RGB channel
flashman2.8
- Version de PhotoFiltre : X
- Système d'exploitation : Windows 7 Home
- Processeur : Intel core i5-2410M 2.3GHz
- Mémoire RAM : 8GB
Re: Swap RGB channel
This function moved in Filter / Color.
flashman2.8
- Mémoire RAM : 8GB
Thanks Tom.
