Seems like a nice program.
BUT
How do I do the basics, such as select then drag and drop?
This is, after all, the most basic function in any drawing package and default in PAINT.
Basic functions
Surfinjo
- Version de PhotoFiltre : 7
- Mémoire RAM : 2k
Re: Basic functions
use the menu Edit > Cut and Edit > Past (or shortcuts Ctr X and Ctr V)
Surfinjo
- Mémoire RAM : 2k
Re: Basic functions
Thank you.
That is how it is done in every graphical program available. It's the first thing I tried.
Sadly, it doesn't work here.
Never mind, found an old copy of PhotoImpact which actually works and a decent help file to go with it.
Good luck with your project.
