"Removing" the background
You need help to start ? Or to use a plugin ? Use the tutorials ! / Ĉu vi bezonas helpon por starti ? Aŭ por uzi etendadon ? Usu la Didaktikojn !
AlfredoT
Version de PhotoFiltre : 6.5.2
Système d'exploitation : XP Pro
Processeur : ASUS
Mémoire RAM : 2 Gb
Message par AlfredoT »
Hello.
I apologize for my English.
I cannot find how to "remove" the background from a picture.
For instance, this very picture http://it.wikipedia.org/wiki/File:Genova-Stemma.png.
I saved it in jpg, then pasted on a colored background.
My problem is to turn the white background into transparen, I guess.
Can anybody help, please?
Thank you! :)
Re: "Removing" the background
JPEG don't support transparency !!!
Only PNG or GIF support transparency :wink:
AlfredoT
Processeur : ASUS
Mémoire RAM : 2 Gb
OIC! :shock: did not know that
1. HOW can I use transparency on a png? I do not know the steps!
2. can I use transparency on a PNG and, after, convert it into jpg maintaining transparency?
Grazie Antonio ;)
AlfredoT
Processeur : ASUS
Mémoire RAM : 2 Gb
Anybody can help, please?
==> some confusion because i tell you that jpeg don't maintain transparency.
Perhaps you can try to find some sites in the web talking about transparency image format to understand better :wink:
I can not explain you correctelly because i don't speak english very well :cry:
AlfredoT
Processeur : ASUS
Mémoire RAM : 2 Gb
No. Using the term "maintain" I understood! :D
I thought in could not be done on it!
Thank you! :)
