text isn't crisp
annew
text isn't crisp
Message par annew »
I'm sorry I don't speak French.
I have designed a banner and posted it at http://gettingyourbookwritten.com/image ... ngeban.jpg
The text doesn't look crisp at the edges. Is it the colors or is there something I'm doing wrong in the compression or the design.
Merci!
A
http://xxxxxxxxxxxxxxxxxx
[Tom] No advertising [/Tom]
Re: text isn't crisp
All font are not antialiased. Try with a TrueType or OpenType font and check the antialias option in the Text module
