how do I make a photo look old?
shagger1
Version de PhotoFiltre : 6
Système d'exploitation : ME/XP
Processeur : intel 1400
Message par shagger1 »
Hi
was wondering how I can make a photo look like a vintage old photo?
I use the regular photofiltre not the studio.....
Regards
Rod
Re: how do I make a photo look old?
Hi Shagger,
did'nt you try the functions of the menu Filter/Aged effect ?
You can also use the PhotoMask module to add some durty masks and scratches.
You can also find some other ways, with an automatic translation tool and a reasarch tool :
http://translate.google.com/translate?h ... 18#p125918
shagger1
Thanks Tom
nice to hear from you-I will try that aged effect,just forgot to look for it!
Rod
