The problem I have is that I cannot add circles with the pointer tool. I can use it for cropping, and changing color, texture etc. I would like to know if there is a plugin dedicated to add adjustable circles to any background. Also, if there is a plugin that handles large bmp's. This is one of the best programs I ever found
Requesting help with making circles
Juan Garcia
Photo Filtre is one of the best things ever happened to me. Thanks to its creators
, very light and fast to load. Thanks for your help.
Re: Requesting help with making circles
In the tools pannel, activate the Selection tool and select the ellipse tool above .
Before drawing You can check the Stroke box above, (the thickness is defined in the Line tools panel.)
or after the selection is drawn : right clic / Stroke and fill. (you can specify the color and the thickness)
You can draw a perfect circle when you maintain the Maj Key, or after drawing the selection clic on the = (square) symbol in the Selection tools.
In menu Selection / Options / Mode / Expand, if selected allows to draw an ellipse around the first position of the pointer.
