6.2.6 doesn't open more than 20 files
Temporary-Failure
- Version de PhotoFiltre : 6.2.6
- Système d'exploitation : Win 7 64bit
- Mémoire RAM : 8GB
I usually drag and drop files into PF but why it's possible to drag and drop only 20 files at once?
Re: 6.2.6 doesn't open more than 20 files
yes, limited to 20 files
Temporary-Failure
- Mémoire RAM : 8GB
for memory problem
You will not edit 20 image at one time, yes ? don't understand ?
Temporary-Failure
- Mémoire RAM : 8GB
I use macromaker with PF which automates cropping, resizing and saving. I have 1300 pics which I have to edit. It's annoying that I have to drag'n'drop only 20 files at once to PF. Is it really that it cannot be 100 files? Or even 50?
it can not be changed, it is in the source code, it is not an option
Temporary-Failure
- Mémoire RAM : 8GB
Well change the source code
