adding black to blue channel
Shinnen
Processeur : Intel p4 2800mhz
Mémoire RAM : 1.5 gig
Message par Shinnen »
Hi,
I read that the blue colour in a blue sky can be made a deeper shade of blue by "adding black to the blue channel".
Does anyone know how I can do that?
Thanks,
....john
Re: adding black to blue channel
You can use the RGB balance or perhaps better, the Gamma correction by channel (with the last version)
Shinnen
Thanks Antonio,
What is the latest version?
..... john
with the V7.1.1 :wink:
Shinnen
Hi Antonio,
Alright, I've upgraded to the latest version. What do you mean by "Gamma correction by channel"?
Thanks,
..... john
with the menu Adjust > Gamma correction you can just change the blue value.
Don't know exactelly what ypou want then it is difficult :wink:
Shinnen
Hi Antonio,
I read that the blue colour in a blue sky can be made a deeper shade of blue by "adding black to the blue channel". That's all I know.
Thanks,
.... john
