Save dialog fails to open if the Save path is invalid
SYSTEM
Version de PhotoFiltre : 7.1.1
Système d'exploitation : Windows 8 Pro
Processeur : AMD A4-3310MX APU (two cores, 2,1 GHz)
Mémoire RAM : 8 GB
Message par SYSTEM »
Steps to reproduce:
  1. Edit the file PhotoFiltre.ini. Set Save to point to a nonexistent directory. (I didn't originally do that – for some reason, additional backslash had appeared at the end of the path.)
  2. Launch PhotoFiltre.
  3. Create an empty picture.
  4. Try to save it.
Defect: the Save dialog fails to open. As a result, saving the picture is impossible.
This is a quite severe problem in my opinion. Inexperienced users will have no idea what is wrong.
Re: Save dialog fails to open if the Save path is invalid
this value is not to bo set manualy, set this using the menu Tools > Preferences > Saving
SYSTEM
Mémoire RAM : 8 GB
Antonio a écrit :this value is not to bo set manualy, set this using the menu Tools > Preferences > Saving
As I said, I didn't set the value manually. I don't know why an additional backslash had appeared.
