Version 6.5.4 in the future?
cameraguy82
Version de PhotoFiltre : 6.5.3
Système d'exploitation : Windows ME
Processeur : Pentium III
Mémoire RAM : 384 MB
Message par cameraguy82 »
Hello,
I love using Photofiltre for retouching/resizing my digital camera pictures. I've been using version 6.5.x for a couple years.
I don't understand using Layers, and there's a few things different between version 7 and 6. Therefore I've decided to continue with version 6.5.3. It's perfect for my needs.
Can I make some suggestions for a possible version 6.5.4? These suggestions have to do with batch conversion.
(1) Add "Auto Contrast" feature to the batch converter
(2) Add "Revive Colors" feature to batch converter
(3) Add "More Shadows" feature to batch converter
... I find myself using the above features most frequently. I do realize the first one is included in PhotoFiltre7, but it would be helpful if they were included in version 6.5
Thank you for listening to my suggestions.
Re: Version 6.5.4 in the future?
for the moment the V6 will not be supported more because lot of work with the studio version and the V7 :cry:
cameraguy82
Okay, thanks.
I use both versions 6 and 7, because I like them both :-)
