Hi,
Is there a raw plugin for Photofiltre 7? I'm trying to open a *.crw file
Thanks,
.... john
Raw plugin
Shinnen
- Mémoire RAM : 1.5 gig
Re: Raw plugin
No raw plugin for the moment. Only the studio version support raw files
Shinnen
Re: Raw plugin
Thanks Antonio...... john
