keep exif data when saving as tiff?
Alain
Mémoire RAM : 1024
Message par Alain »
Hi
Am I coorect that photofiltre doesn't keep the exif data when saving a jpeg as tiff?
Is planned or not possible?
The reason I ask that I'm thinking of first batch saving my jpeg's as tiff, then run picture cooler (noise reduction) on them, reopen them in photofiltre and do the "stuff" there and only saving them as jpeg when they are final.
In that way I won't loose quality while doing my work even in multiple sessions...
Alain
Yes i want to do this but i don't know when...
Alain
Mémoire RAM : 1024
Message par Alain »
Antonio a écrit :Yes i want to do this but i don't know when...
Ok, thanks for replying. I fully understand you...
