Merging pictures
Shinnen
Processeur : Intel p4 2800mhz
Mémoire RAM : 1.5 gig
Merging pictures
Message par Shinnen »
Hi,
Is there a way of merging several images? I found that merging images can improve their quality, especially in low light conditions. Right now I open them in separate layers, then hit merge all. But is there a way of opening several images and then merging them all in one operation?
Thanks,
..... john
Re: Merging pictures
Hi John,
merging several images in normal mode improves evidently their quality because if you do a try with 3 images
and want to give them the same importance, you have to divide opacity of each layer by 3,
so you get 33% for each layer, and the 100% of the background are only visible for 33% .
But if you give us a concrete example of that you want to do, perhaps can we find a way to merge the layers
with an appropriate blending mode.
To merge all layers in one operation : shift enter : menu Layer/Merge all layers
