Radial gradient in PF 7
chicchio
Version de PhotoFiltre : 7.0.1
Système d'exploitation : xp pro sp3
Message par chicchio »
Hi to all !
Maybe I have not searched in deep, but I cannot find how to have a radial gradient in PF7.
I also would like to use this radial gradient as a mask/transparency layer.
What I am trying to obtain is a sort of vignetting of the image, reducing the brightness of the borders, using a radial black layer.
Thanks for any help on this.
Chicchio
Re: Radial gradient in PF 7
Hi chicchio,
menu Filter / Other / Radial mask
A tutoriel to use the mask in the Alpha channel of a layer :
http://translate.google.fr/translate?sl ... ml&act=url
chicchio
Tom,
many thanks ! I must go to the doctor, and control my eyes... !
Many thanks also for the tutorial, now I can do exactly the effect that I wanted. And finally, thanks to Antonio and all the staff for this wonderful software !
Chicchio
