I have PPP_III-en.exe that I downloaded about 1 year ago. Is this the same file that is currently marked as PPP_III-en.exe in the plugins section of the website, i.e. has it been changed or updated?
Thanks,
...... john
updates
Re: updates
If you allready had all needed plugins, don't need to update because plugins don't changed
Shinnen
- Mémoire RAM : 1.5 gig
Re: updates
Thanks Antonio. And...... thanks for this program.
..... john
..... john
Shinnen
Re: updates
Hi appedology,
It's been so long since I posted my original question that I don't even recall what the issue was, but thanks for replying.
...... john
...... john
