Photofiltre and opening and saving folders settings
shagger1
Version de PhotoFiltre : 6
Système d'exploitation : ME/XP
Processeur : intel 1400
Message par shagger1 »
Hi
I notice than in options in the program(not the studio version) there are settings for folders-opening folder and saving folder-the problem I am having is if I open a folder within what I have it set for,and delete that folder next time I use the program it wants to open that folder which I deleted and does not open the folder I have it set for,in my case I have a folder called Dow Files,and it open the photofiltre folder in program files-anyway to avoid this?I checked the lock folders bot but that did not seem to do the trick.I use version 624 on XP.
Thanks
Rod
Re: Photofiltre and opening and saving folders settings
photofiltre check if the folder exit at startup, if it don't exist, PhotoFiltre reset the folder
shagger1
I understand now,the first time in years it has ever done that!
Thanks Antonio
Rod
