Color balance
chicchio
Version de PhotoFiltre : 7.0.1
Système d'exploitation : xp pro sp3
Color balance
Message par chicchio »
Hallo !
I am using PhotoFiltre Free 7.0.1 "portable" version (the zip one) and I have a little problem.
When I use the Color Balance, settings are stored and come back everytime I load an image.
In other words, I open an image, then open the Color Balance panel, then I set, for example, Cyan - Red - 10%. Now, this value is stored and comes back everytime I run PF, and everytime I load an image, no matter how many times I click restore. The only way to reset this value is to delete the file PhotoFiltreDialogs.ini
I think that values should go back to default when I close PF7; am I wrong ?
I have this error with Windows XP Pro SP3 and with Windows 7 pro.
Thanks in advance for any help,
Enrico
Re: Color balance
it is not an error or bug, the majority of users want that values are restored ! :wink:
Got o the menu Tool > Preferences > default values
chicchio
Re: Color balance
OK Antonio, thanks for the quick answer.
Now I know how to deal with these values, I will continue to enjoy with PF7.
Thank you again.
Enrico
Re: Color balance
Got o the menu Tool > Preferences > default values to disable this option
Josi
Re: Color balance / Contrast / Brightness
Message par Josi »
I have the same problem as chicchio. Though I have disabled "Memorize Parametres" in Werkzeuge (tools) -> Einstellungen (options) -> Voreinstellungen (presettings), Photofiltre 7 still memorizes the settings of brightness, contrast, colour settings etc of the former photo. Only if I leave the programme and start again the settings on zero for one photo. It's a nuisance which causes much extra work for you to go through all kind of filtres and undo the settings to see what the original photo looked like and then decide what you want to change in it. The lighting and colouring is different in each photo I take so why would I want to use the settings of one photo for the next? It would be grand of the original setting would be on zero for each photo and those who want to use the same settings for each photo should be able to choose that under options. But in my opinion it's no good idea to change settings before having evaluated the original photo. That was far better in photofiltre 6.
So how do I disable the memorizing of the parametres? For I would hate to have to go back to version 6 for 7 has some nice new options in other regards.
Re: Color balance
I understand but for the moment it is not possible. But don't forget the button Reset.
Lot of user want to save values and lot of other don't want :cry:
Re: Color balance
i will add an option in the next version to auto reset...
