I upgraded to version 7 in the hope that it might work better than 6 in Win 7 when trying to acquire image via Scanner. It does work better, thanks. (I still get an error message, 'violation d'acces...' but I just click on OK and it goes.)
However, I find that the ordinary 'paste' function doesn't work without very complicated 'layer' functions which I don't understand and don't need. So I have to open version 6 to perform these simple functions. Any way round this?
Pasting in version 7
escoville
- Version de PhotoFiltre : 6.5.2 + 7.0.1
- Système d'exploitation : Win7
- Processeur : Pentium D930
- Mémoire RAM : 2048MB
Re: Pasting in version 7
use the menu Layer > Marge all layers or CTRL+ENTER
But it is not a problem to have lot of layers because when you save as JPEG or PNG the image is flatten
dvip
Antonio, how about an option to allow the ordinary "Paste" function?
Ctrl+V is very universal (like version 6). I think it should be easy to implement.
Using the menu Layer > Merge all layers or CTRL+ENTER is fine, but it can confuse users.
Perhaps the menu can give you an option on how Paste should work.
Also, please add:
- Shadow recover
- Highlight recover
- A better Dust/Noise reduction
Also, please add:
- Shadow recover
- Highlight recover
