How to transfer uploaded pictures to my folders
trackfodder
Version de PhotoFiltre : 6.5.2
Système d'exploitation : windows7 sevice pack 1
Processeur : 32 bitAMD Phenom9750 quad core4Gb
Mémoire RAM : 4Gb
Message par trackfodder »
I uploaded some pictures from my Canon dig. camera and they didn't go to picture library, but was able to call them up in Photofiltre, where I re-sized them, but can't figure out how to move them to a place I can browse them and put in emails. Keith Williams
Re: How to transfer uploaded pictures to my folders
Hi,
menu Tools / Image explorer and do a right click in the bottom tin window to see the contextual menu.
But you should try to use Explorateur Windows to figure out how your files and folders are managed on your hard drive.
trackfodder
Mémoire RAM : 4Gb
trackfodder a écrit :I uploaded some pictures from my Canon dig. camera and they didn't go to picture library, but was able to call them up in Photofiltre, where I re-sized them, but can't figure out how to move them to a place I can browse them and put in emails. Keith Williams
My Romanian grandson-in-law in Tulsa solved the problem. I clicked save as and put them on desktop. However, when I browsed, I found thumbnails available on the selection of storage sites. Thanx anyhow. Keith Williams
Fine ! you have a quick solution, and i'm happy for you. :)
But mind : the desktop is a special system folder and not a good folder to load heavy files durably.
You should use or create a personnal folder for your pictures and have a shortcut for it on your desktop.
