Crop layer option grayed out when using multi layers.
sether
Message par sether »
How to use the crop layer function.
I accidently used it 1 time when messing arround but can find how again.
I want to crop / cut a part from a background image based on the size of multiple layers.
This is when using one of the many facebook cover PSD layer templates, however the crop layer function is grey and not possible to select.
Re: Crop layer option grayed out when using multi layers.
Hi,
the background is not a layer as others, and if you wish to keep transparent the part to crop, the image must be in RVBA mode (with an Alphachanel).
It's the reason why : menu Image/Mode exist.
But if perhaps you want to crop the image try the crop function in the Image menu or a right clic in the sélection on the right layer.
