Redfield ATX problem
Don key
Version de PhotoFiltre : studio x 10.62
Message par Don key »
Hi !
Plugins ne fonctionnent que Redfield ancienne version. Redfield ATX ne fonctionnent pas ancien et le nouveau. Pourquoi?
Redfield plugins work only old version. Redfield ATX dont work old and new. Why? :(
http://www.redfieldplugins.com/filterATX.htm
Re: Redfield ATX problem
No change for the 8BF lib since 2005, i think the problem is not the new version but plugin setting or PhotoFiltre Studio setting...
Hi,
Redfield ATX 8bf Plugin is a shareware one : US $ : 39.90
If you have reached the time limit of the demo, i think that some flag is closed in the registry.
Other freware plugins from Redfield are matchnig very well.
Don key
Hi,
Even the demo does not work.
Tom ,please try for yourself and tell me the result, if does not work - hence it is only Adobe Photoshop (specific API .8bf) plugin.
I have downloaded the last version of "Face Control" freeware from Redfield and it works very well.
Yes for a shareware file if the trial time is over, the demo is stoned, no wonder in that.
Other way you can contact the Redfield support if your rights are registered or if you try this product for the first time.
Don key
thank you, Tom !
in my PF SX plugin 'Face Control' 1.25 - work, 2.00 - not work.This is very strange.....
Some files are perhaps corrupted. Try to re-install PhotoFiltre.
