copy and paste.
Shinnen
Processeur : Intel p4 2800mhz
Mémoire RAM : 1.5 gig
copy and paste.
Message par Shinnen »
Hi,
I would like to copy a statue from picture A and paste it into picture B.
I have isolated the statue, and I think made the background (A) transparent,
well.... it's white; but when I copy and paste this picture into picture B, it
just covers it ...... showing a white background. Do I make the background of A
transparent before I copy it, or after I paste it in, and how do I do it?
Thanks,
..... john
P.S. Is there any tutorials available about how to do transparencies?
Re: copy and paste.
HI,
:shock: :shock: :shock:
  • select any area you want
  • copy
  • open the target image
  • paste
But you must do these operations in the same instance of PhotoFiltre.
If it doesn't work with transparency, the Windows Clipboard is out of order. Restart Windows and PhotoFiltre.
Other way you can do like this tutorial of the official site :
http://photofiltre.free.fr/tutoriels/op ... ipping.htm
