pixel art and sprite animation ?
kilele
Message par kilele »
Hi
is there some tutorial about animation of pixel art sprites ? thanks
Edit:
I would like to use Photofiltre with some features of a pretty simple but handy program: IconXP (Aha-soft),
with this program I can move from frame to frame using cursors, and restrict the palette to a determined/fixed number of colors, this two things help to make animations with fluidity, besides it has a preview window to see the result on a different scale. Another program used by many pixel-artists is GraphicsGale off which Photofiltre might adopt some features :)
kilele
Re: pixel art and sprite animation ?
I answer to myself ^^
so.. is there a quick way in Photofiltre to flip between layers by means of keystrokes like I mentioned using cursors on that other program? thanks in advance
Hi, now i understand . :)
Keyboards F6 Up and F7 Down.
For more informations ou can use an automatic translation of the documentation :
http://translate.google.com/translate?h ... /index.htm
Or in this page for keyboard shortcuts :
http://translate.google.com/translate?h ... ourcis.htm
