Hi,
Can anyone tell me how to display the exif information in Photofiltre 7?
Thanks,
...... john
exif information
- Mémoire RAM : 1.5 gig
Re: exif information
Hi John,
you already have the good link : viewtopic.php?p=167957#p167957
On the first page of the documentation (after the cover) : Image properties.
Evidently if the exifs aren't be saved you don't will see the exif thumb in the propoerties.
Hi Tom,
OK...... I've got it. Ctrl J or the File menu. I don't know how I missed it..... I must be blind.
Thanks,
....... john
Thanks,
....... john
Hi Tom,
Do you know of a way of getting Photofiltre to automatically display the exif information, for example at the right side of the picture, where there is normally a large empty space.
Thanks,
..... john
Thanks,
..... john
No but you can export a text file and copy / paste that tou want where you want.
Hi,
Yes...... well ....... I'm just interesting in viewing it, each time I open a picture.
I do a lot of comparisons when I'm trying to understand a photographic method, or setting,
so it would be nice if it were just 'there' every time.
...... john
...... john
For this, use XnView (very good freeware), which is dedicated principaly as a viewer and cataloger : you have an exif thumb in the Display window.
Just clic on the images thumbs of the folder window and you can compare in the Display window the exif matching with each image thumb.
exif information
Hi Tom,
Thanks. I'll look into XnView. Right now I use Faststone for comparing images and
settings, but it's exif information is not very extensive. Otherwise it's an excellent app.
..... john
..... john
